Re: How to export surfaces without solid bodies
Kyle Mitchell Jan 17, 2018 3:13 AM (in response to Igor Fomenko)Hi Igor,
There are a couple of ways of achieving this. You can use delete bodies command to remove the surfaces you don't want, then export to step after this. Or you could use insert in to new part to save the body you want in to a separate file, then export to step from there.
Thanks, Kyle
Igor Fomenko Jan 17, 2018 3:17 AM (in response to Kyle Mitchell)Kyle Mitchell wrote:
Hi Igor,
Thanks, Kyle
I need to hide BODIES, I found one way with iges
Only last item gives shell assembly without solids.
Kyle Mitchell Jan 17, 2018 3:25 AM (in response to Igor Fomenko)Igor,
Are you working in an assembly or multibody part environment?
If in an assembly, open the part and export from the part file using the method mentioned above?
Igor Fomenko Jan 17, 2018 4:06 AM (in response to Igor Fomenko) -
Rob Edwards Jan 17, 2018 3:21 AM (in response to Igor Fomenko) -
Tateos Tvapanyan Jan 17, 2018 3:25 AM (in response to Igor Fomenko)Create an export configuration and delete the bodies you don't want to export.
Igor Fomenko Jan 17, 2018 3:45 AM (in response to Igor Fomenko)Guys, thank you, please read carefully, I have assemby with two configurations: solid and shell (for export), I dont want to delete or supress bodies (in this case I loose mates). I export this shell assembly and fortunately only iges and only with Bounded surface option gives me desired result.
Kyle Mitchell Jan 17, 2018 3:42 AM (in response to Igor Fomenko)Could you attach the files? Or recreate the problem if you don't want to?
Another thought could be to add a new empty part to the assembly. Edit this part within the assembly and copy the desired surfaces. Then you can open this part file separately, containing only the required surfaces and export to step. This can then be suppressed in the assembly.
Igor Fomenko Jan 17, 2018 3:51 AM (in response to Igor Fomenko)-
Re: How to export surfaces and sketches without solid bodies
Elmar Klammer Jan 17, 2018 4:59 AM (in response to Igor Fomenko)Hi Igor,
You need to set your iges import settings "Free point/curve entities" to enabled and your sketches should come in.
Elmar
Igor Fomenko Jan 17, 2018 5:26 AM (in response to Elmar Klammer)Thank you, I forget about import options, but I try to import not from SWX, STEP is OK without this option
Igor Fomenko Jan 17, 2018 5:38 AM (in response to Elmar Klammer)Do you know how to prevent step export from tranferring of solid geometry?
Elmar Klammer Jan 17, 2018 6:25 AM (in response to Igor Fomenko)Hi Igor,
If you work with parts then simply add a delete body feature before you export the file. If my parts are part of an assembly then I simply
batch all the parts. Adding the delete feature without saving gives me the assembly with all surfaces. If you are concerned about mate issues, then I would suggest you fix all parts in the assembly and suppress the mates before you export it out.
Exporting out cuts the parametric link anyways. Not sure if Simulation software has the ability to update modified dumb solids as SW has introduced with 3Dinterconnect.
Elmar
Igor Fomenko Jan 18, 2018 11:39 AM (in response to Elmar Klammer)OK,thank you, I know these workarounds, I wanted to publish ability to dont export hidden bodies for TOP TEN but some guy (may be Deepak) said that it is already done by this dialog
but unfortunately it doesn`t work. Hidden bodies export anyway for STEP and only IGS works right.
Moreover if you answer YES you'll get a lot of enveloped parts and subassemblies (SWX18.0).
