Hi
I've got an assembly with 2 intersecting parts. I want to leave B unchanged, but create a cut (recess) in A where it intersects with B.
This is a simplified example - the real assembly I'm working on is much more complicated so creating the recess manually is a lot of work, and I need it to change as the shape of B changes.
Is this possible? I know there's an Intersect feature in SW 2013 onwards, but I'm using 2012.
Many thanks
Edit Part A in context.
Then use the Cavity tool.
Done.
Edit: See the attached video.
