Is there a way to keep the bounding box that was added in 2018 from showing besides the setting in Visibility on/off or not using it at all. When the size of the part changes any the bounding box turns itself back on. This is a real pain when you go to the drawing and the box is visible once again. Plus when it's visible in the drawing, this then makes it a pickable object & that causes issues. If an ordinate dimension is started and uses an edge of the bounding box as the origin, I've had the zero dimension flip to the other edge of the view because the bounding box changed with the part change. IMO the bounding box SHOULD NEVER be an object that can be picked in a drawing or there should be some type of setting to control that if a person would want to dimension to show overall stock size on a part
Is this the box you are talking about?
