Hello SoldiWorks team!
How can i stop WRAP command to merge the resulting bodies? I would like to make a bracing collar around a tube stub in a cylindrical tank and make a manufacturing drawing from it.
Thank you for your help,
Robert
Robert
Hey Robert,
I am sure there are a few ways of doing this. Here is just one...
First, use the Wrap tool to create a 'scribe' on the surface as opposed to an emboss or deboss...
Next, create an Offset Surface at 0mm on the newly created scribe face...
Then, use the Wrap tool again using the same sketch used on the first Wrap to create an emboss onto this newly created surface body...
Finally, use the Intersect tool to intersect the solid body, and the surface body. Be sure to clear the 'merge results' box, and click the green check!
Done!
