Heat transfer coefficient for convection
Question asked by Per Mjörnstad on Jan 15, 2018
Latest reply on Feb 1, 2018 by Ryan Dark
Hello
I want to test different nozzles and se which one has the best heat transfer coefficient.
The nozzle are blowing on a Surface the static pressure of air is 1000Pa and the air temp is 20degrees.
The Surface is set to 300degrees constant.
I run the test and get very differen values on the heat transfer coefficient with the same nozzle.
but with different meshes.
So my question is what mesh should i use ?
Best Regards
Per
