Hi!
I have found on the internet one macro that I would like to improve. It opens up assembly and exports each part weight. In the end I would like to get macro which opens up assembly, then reads dimensions of part and export that information to excel. Main purpose of that would be knowing how much of different metal sheet would be needed to make the parts from assembly. I understand that getpartbox function returns not so precise information, especially if that part has irregular shape. However, for me it is not so important, getpartbox function would be suitable for me.
Here is the original macro that I have found:
Dim SwModel As SldWorks.ModelDoc2
Dim swModExt As SldWorks.ModelDocExtension
Dim swAssembly As SldWorks.AssemblyDoc
Dim SwComp As SldWorks.Component2
Dim MassProp As SldWorks.MassProperty
Dim Component As Variant
Dim Components As Variant
Dim Bodies As Variant
Dim BodyInfo As Variant
Dim CenOfM As Variant
Dim RetBool As Boolean
Dim RetVal As Long
Dim xlApp As Excel.Application
Dim xlWorkBooks As Excel.Workbooks
Dim xlBook As Excel.Workbook
Dim xlsheet As Excel.Worksheet
Dim OutputPath As String
Dim OutputFN As String
Dim xlCurRow As Integer
Set SwModel = swApp.ActiveDoc
If SwModel Is Nothing Then
swApp.SendMsgToUser2 "An assembly must be an active document.", swMbWarning, swMbOk
Exit Sub
If SwModel.GetType <> swDocASSEMBLY Then
Exit Sub
Else
Set swAssembly = SwModel
Set swModExt = SwModel.Extension
Set MassProp = swModExt.CreateMassProperty
OutputPath = Environ("USERPROFILE") & "\Desktop\"
OutputFN = SwModel.GetTitle & ".xlsx"
If Dir(OutputPath & OutputFN) <> "" Then
Kill OutputPath & OutputFN
Set xlApp = Excel.Application
xlApp.Visible = True
Set xlWorkBooks = Excel.Workbooks
Set xlBook = xlWorkBooks.Add()
Set xlsheet = xlBook.Worksheets("Sheet1")
xlsheet.Range("A1").Value = "Component"
xlsheet.Range("B1").Value = "X Loc (mm)"
xlsheet.Range("C1").Value = "Y Loc (mm)"
xlsheet.Range("D1").Value = "Z Loc (mm)"
xlsheet.Range("E1").Value = "Mass (kg)"
xlsheet.Range("F1").Value = "Type"
xlBook.SaveAs OutputPath & OutputFN
xlCurRow = 2
RetVal = swAssembly.ResolveAllLightWeightComponents(False)
Components = swAssembly.GetComponents(False)
For Each Component In Components
Set SwComp = Component
If SwComp.GetSuppression <> 0 Then
'If LCase(Right(SwComp.GetPathName, 3)) <> "asm" Then
Bodies = SwComp.GetBodies2(0)
'MsgBox SwComp.Name
'If Bodies <> Empty Then
RetBool = MassProp.AddBodies(Bodies)
CenOfM = MassProp.CenterOfMass
xlsheet.Range("A" & xlCurRow).Value = SwComp.Name
xlsheet.Range("B" & xlCurRow).Value = CenOfM(0) * 1000
xlsheet.Range("C" & xlCurRow).Value = CenOfM(1) * 1000
xlsheet.Range("D" & xlCurRow).Value = CenOfM(2) * 1000
xlsheet.Range("E" & xlCurRow).Value = MassProp.Mass
If LCase(Right(SwComp.GetPathName, 3)) = "asm" Then
xlsheet.Range("F" & xlCurRow).Value = "Assembly"
ElseIf LCase(Right(SwComp.GetPathName, 3)) = "prt" Then
xlsheet.Range("F" & xlCurRow).Value = "Part"
Else
xlsheet.Range("F" & xlCurRow).Value = "Undetermined"
End If 'Right 3 of file extension
xlCurRow = xlCurRow + 1
'End If 'UBound(Bodies) <> -1
'End If 'Not an Assembly
End If 'swComp.GetSuppression <> 0
Next Component
xlsheet.UsedRange.EntireColumn.AutoFit
xlBook.Save
'xlWorkBooks.Close
'xlApp.Quit
I will remind that I am only beginner. I found the spot where macro start putting information into excel cells. I tried adding there this getpartbox function, but I get error. I cannot figure out why it does not like it. I get error "Object doesn' t support this property or method".
Here is "my edited" code
Dim RetVal As Long
Dim SolidWorksPartCorners As Variant
Exit Sub
Exit Sub
Else
xlCurRow = 2
'MsgBox SwComp.Name
' ' CenOfM = MassProp.CenterOfMass
' ' xlsheet.Range("B" & xlCurRow).Value = CenOfM(0) * 1000
' ' xlsheet.Range("C" & xlCurRow).Value = CenOfM(1) * 1000
' ' xlsheet.Range("D" & xlCurRow).Value = CenOfM(2) * 1000
Else
SolidWorksPartCorners = SwModel.GetPartBox(True)
Next Component
xlBook.Save
'xlWorkBooks.Close
'xlApp.Quit
Can you help me fix this problem, so I can continue editing this script?
