15 Replies Latest reply on Jan 15, 2018 11:12 PM by Mr Omkar Deshpande
    Help with mouse events
    Prashant Mohan
      I have a simple macro that notifies whenever left mouse button is pressed. and shows the coordinates of the mouse pointer. There is a form with a button on it. When you press the button it starts the mouse event.  I want to know how do i bring the command back to code (main) after the event it fired. If you look below i want "Hey" to be displayed after the i press the left mouse button and coordinates at the mouse tip are shown.
      I have attached the code as well
      I am new to mouse events and did not find anything that could solve this problem. Any help will be appreciated.
          UserForm1.Show vbModeless
          MsgBox ("Hey")
      Dim swView As SldWorks.ModelView
      Dim WithEvents swMouse As SldWorks.Mouse
      Dim X_, Y_ As Double
      Dim listenForClick As Boolean
      Private Sub CommandButton1_Click()
          Set swModel = swApp.ActiveDoc
          Set swView = swModel.ActiveView
          Set swMouse = swView.GetMouse
          listenForClick = True
      Private Function swMouse_MouseLBtnDownNotify(ByVal X As Long, ByVal Y As Long, ByVal WParam As Long) As Long
          If listenForClick Then
              X_ = X
              Y_ = Y
              MsgBox (X & "; " & Y)
              listenForClick = False
              Unload UserForm1
      End Function
      Private Sub UserForm_Initialize()
        • Re: Help with mouse events
          Rajat Jain
          Hi Prashant,
          I think the simplest approach for you is to show your form as Modal form. This would solve your issue.
               UserForm1.Show vbModal
                  MsgBox ("Hey")
          Hope it helps!!!
          Rajat Jain
            Rob Edwards
            Prashant
            I can see you got your answer which is great:)  I am interested in learning how to handle events so had a go at this myself and got something that seems to work, but I am not sure if it is a good way or not.  Whilst I was working it out I found I had to be very careful or Solidworks would crash when I unloaded the form or set the mouse to Nothing in the wrong place.
            I would love to hear from an expert if the following apporoach is 'a good' or 'a bad' idea.  Josh . Please would you be kind enough to comment
            Public e As MyEvents
                Set e = New MyEvents
            Public Function ShowForm()
            End Function
            Public Function CloseForm()
                Unload UserForm1
            End Function
            Public Function DoNextThing()
                MsgBox ("Hey!")
            End Function
            Public Function Finish()
                Debug.Print ("finish events")
                Set e = Nothing
            End Function
            'MyEvents Class
            Option Explicit
            Dim WithEvents swapp As SldWorks.SldWorks
            Public taskcounter As Integer
            Dim taskComplete(4) As Boolean
            Sub class_initialize()
                Set swapp = Application.SldWorks
                taskcounter = 0
            Public Function NextTask()
                taskComplete(taskcounter) = True
                taskcounter = taskcounter + 1
            End Function
            Public Function swApp_OnIdleNotify() As Long
                Debug.Print "idle"
                If Not taskComplete(taskcounter) Then
                    Select Case taskcounter
                    Case 0
                            Me.NextTask
                            Call ShowForm
                            Set swMouse = swapp.ActiveDoc.ActiveView.GetMouse
                    Case 1
                            Rem wait
                            ' progression controlled by mouse handler
                    Case 2
                            Me.NextTask
                            Set swMouse = Nothing
                            Call CloseForm
                    Case 3
                            Me.NextTask
                            Call DoNextThing
                    Case 4
                            Me.NextTask
                            Call Finish
                    End Select
            End Function
                If UserForm1.CheckBox1.Value Then
                    MsgBox "x:" & X & " y:" & Y
                Else
                    Me.NextTask
            End Function
                Josh Brady
                Rob... It seems like you're trying to make a macro-in-progress sit and wait.  You really don't want to do that.
                The reason Prashant has a UserForm is (I assume) that you can't declare WithEvents variables in a regular module.  You have to use a Class Module or a UserForm.
                Once you declare something WithEvents, you'll get notified whenever the event you're interested in happens to the object that's WithEvents'd.  As long as that object exists (isn't Nothing and doesn't go out of scope), you'll get the notification.
                As long as a form is loaded, it's variables declared at Module Level don't go out of scope.  They belong to the form.  Once the form is unloaded, they go out of existence and you don't get the notify anymore.
                A class module is sort of like the form, except that it's not visible.  Once you instantiate it, it won't go away until you set it to Nothing.  The class instance will sit there just like the form does and wait for you to do something with it.  It can close itself too.
                This may or may not make sense.  I'm typing stream of consciousness.
