i am trying to put a chamfer on a hole that is on a curved surface but i cant seem to get it to work with the chamfer tool.
see below:
this was made with a revolve (what i wanted)
this is what the chamfer tool does (not desired)
any way to make the chamfer like the top one in the tool?
In reality SW Chamfer Tool tries to stay perpendicular to the surface as it shows in the top picture, which could be right if the part was chamfered prior to forming.
To achieve the image in the bottom picture you would need to have a fixture to hold the pc at that angle to chamfer it.
The question is - when will you be putting the chamfer in before or after bending?
