Renumber Sheet Names and Relabel View Labels
Question asked by Matt Peneguy on Jan 11, 2018
Latest reply on Aug 12, 2020 by Matt Peneguy
In another thread I mentioned that I manually renumbered my sheet names.  I have the name linked to a field on the sheet.  This is a good way of ordering the sheets and since I have multiple files with multiple sheets for each project. But, I have to change a lot if a sheet is inserted.  Well, Deepak Gupta mentioned that I may want to create a macro.  I did just that by copying a macro from the help and modifying it.  I thought I'd post it in a new thread to make it easier to find... And here it is (I hope it doesn't offend anyone who knows how to properly code, but I will modify it if anyone sees anything wrong):
Edit to Add:
With guidance from Deepak Gupta I have modified the macro to first change the name of the sheets to a "dummy" name to prevent an error when renumbering the sheets if a sheet name already exists (if the above macro tries to name a sheet 2 and that name already exists, it fails).  Thanks Deepak!
Dim vSheetName As Variant
Dim i As Integer
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
myNum = InputBox("Enter the first sheet number")
If IsNumeric(myNum) = False Then
    MsgBox ("Enter a numeric value and retry")
    Exit Sub
' Rename the sheets to a dummy name
RenameSheets ("99999999")
RenameSheets (myNum)
Sub RenameSheets(myName)
vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
    mynewNum = myName + i
    bRet = swDraw.ActivateSheet(vSheetName(i))
    Dim swSheet As Sheet
    Set swSheet = swDraw.Sheet(vSheetName(i))
    If (swSheet.IsLoaded) Then
       swSheet.SetName mynewNum
    Else
        Debug.Print (vSheetName(i) & " is not loaded.")
    Next i
Edit to add2: Thanks to Deepak Gupta I copied the code written by Artem Taturevych and modified it to label past 26 views (A-Z).  It should handle AA-ZZ, now (I think that works out to 702 views).  A lot of workflows don't go past 26 views, but some of our drawing files do.  Anyone interested can see the attached file.
Sorry Artem, my code is nowhere near as neat and tidy as yours, but what I kludged together should work.
