12 Replies Latest reply on Jan 16, 2018 9:58 AM by Shaun Jalbert
    Save as DWG with Defined Settings
    Shaun Jalbert
      We want to create a new Save as DWG macro so that anyone who uses it, gets the exact same results. It needs to:
      1) save to specified folder ("<user>\Desktop\Export\")
      2) use a predefined mapping file ("C:\EPDM_Vault\Templates\DWG Mapping Files\101517-mapping")
      3) Along with the following settings established.
      Below is a sample of an attempt. I'm able to get the file to save to the right location, but I'm baffled on how to specify the mapping file and other specific settings. Can anyone shed some light on this for me?
      Dim sFileName As String
      Dim sPathName As String
      Dim strFullPath As String
      Dim bRet As Boolean
      Dim nErrors As Long
      Dim nWarnings As Long
          Set swModel = swApp.ActiveDoc
          sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
          sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
          sPathName = Environ("USERPROFILE") & "\Desktop\Export\"
          If Dir(sPathName) = "" Then
              MkDir sPathName
          sPathName = sPathName & sFileName & ".DWG"
                 ' Show current settings
          Debug.Print "DxfMapping             = " & swApp.GetUserPreferenceToggle(swDxfMapping)
          Debug.Print "DXFDontShowMap         = " & swApp.GetUserPreferenceToggle(swDXFDontShowMap)
          Debug.Print "DxfVersion             = " & swApp.GetUserPreferenceIntegerValue(swDxfVersion)
          Debug.Print "DxfOutputFonts         = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputFonts)
          Debug.Print "DxfMappingFileIndex    = " & swApp.GetUserPreferenceIntegerValue(swDxfMappingFileIndex)
          Debug.Print "DxfOutputLineStyles    = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputLineStyles)
          Debug.Print "DxfOutputNoScale       = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputNoScale)
          Debug.Print "DxfMappingFiles        = " & swApp.GetUserPreferenceStringListValue(swDxfMappingFiles)
          Debug.Print "DxfOutputScaleFactor   = " & swApp.GetUserPreferenceDoubleValue(swDxfOutputScaleFactor)
          Debug.Print ""
          ' Turn off showing of map
          bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
          Debug.Print "bShowMap = " & bShowMap
          bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
          Beep
          If bRet = False Then
              swApp.SendMsgToUser2 "Problems saving file.", swMbWarning, swMbOk
          ' Restore old setting
          swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
          • Re: Save as DWG with Defined Settings
            Shaun Jalbert
            Hmm... Looked at this. Looks like this would solve item 2) in my list. I tried it, but it didn't work.
            Also, this doesn't address item 3) at all either.
            Anyway, this was my latest attempt.
            'Save DWG in Specified Folder.swp
            'Description: Macro to export Drawing File as DWG in specified location.
            'Pre-Condition: An active drawing file.
            'Post-Condition: Macro will export the active Drawing File as DWG in specified location
            Dim bRet As Boolean
            Dim nErrors As Long
            Dim CustomMap As String
                    MkDir sPathName
                CustomMap = "C:\EPDM_Vault\Templates\DWG Mapping Files\101517-mapping"
                Debug.Print ""
                swApp.SetUserPreferenceToggle swDXFDontShowMap, False
                           swApp.SetUserPreferenceStringListValue swDxfMappingFiles, CustomMap
                           Index = swApp.GetUserPreferenceIntegerValue(swDxfMappingFileIndex)
                           If (Index = -1) Then
                           swApp.SetUserPreferenceIntegerValue swDxfMappingFileIndex, 0
                     nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
              Shaun Jalbert
              Looks like these are what I want to set for task item #3) in my list.
              How do I call these out?
              2016 api - File > Save As > Save as type > Dxf or Dwg > Options
                  Deepak Gupta
                  You can call those options using SetUserPreferenceIntegerValue and SetUserPreferenceToggle
                      Shaun Jalbert
                      Deepak:
                      I'm not a programmer, so please bare with me. I'm having trouble calling out those options.
                      I've declared the following:
                           Dim instance As ISldWorks
                           Dim UserPreferenceValue As System.Integer
                           Dim OnFlag As System.Boolean
                      Then Called out the setting as:
                           ' Set Client specific settings
                           ISldWorks::SetUserPreferenceToggle(swUserPreferenceToggle_e.swDXFExportHiddenLayersOn, OnFlag)
                      but I get the following error.
                      Not sure what I'm doing wrong?
                          Alex Burnett
                          According to your full code above, you're pretty much there. Just call out the commands as follows. It will fail if you put parenthesis unless you set it to a return value. The syntax you need is here:
                          swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfMapping, false
                          The list of settings in my c# program are below. These can be translated easily into VBA and get you pointed in the right direction.
                          ///  .dxf
                          ///  .dwg
                          ///  flat.dxf
                          // DXF Version
                          swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfVersion, (int)swDxfFormat_e.swDxfFormat_R2000);
                          // Fonts (0 use AUTOCAD FONTS, 1 use TRUE TYPE)
                          swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputFonts, 0);
                          // Line Styles (0 use AUTOCAD STANDARD, 1 use CUSTOM)
                          swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputLineStyles, 0);
                          // Custom Map Solidworks to DXF/DWG
                          swApp.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfMapping, false);
                          // Scale output
                          swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputNoScale, 0);
                          // Endpoint Merging
                          swApp.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfEndPointMerge, false);
                          // Spline Export Options
                          swApp.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfExportSplinesAsSplines, true);
                          // Multisheet Options
                          swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, (int)swDxfMultisheet_e.swDxfMultiSheet);
                          Shaun Jalbert
                          Ok, I think I figured out the callouts - as follows:
                          ' Set specific Version
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfVersion, swDxfFormat.e.Value) = 6
                          ' Set specific Fonts
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputFonts, swDxfFormat.e.Value) = 1
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputLineStyles, swDxfFormat.e.Value) = 1
                          ' Enable specific Custom Map SOLIDWORKS to DXF/DWG
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfMapping, OnFlag) = True
                          ' Custom Map SOLIDWORKS to DXF/DWG - Don't show mapping on each save
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDXFDontShowMap, OnFlag) = True
                          ' Custom Map SOLIDWORKS to DXF/DWG - Map file
                          ISldWorks:: SetUserPreferenceStringListValue(swUserPreferenceStringListValue_e.swDxfMappingFiles, Value) = CustomMap
                          ' Enable Scale output 1:1
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfOutputNoScale, Value) = True
                          ' Scale output 1:1 - Base scale - NOT AVAILABLE IN SW2017 API
                          ' Scale output 1:1 - Warn me if enabled - NOT AVAILABLE IN SW2017 API
                          ' Enable End Point Merging
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfEndPointMerge, OnFlag) = True
                          ' End Point Merging Tolerance
                          ISldWorks:: SetUserPreferenceDoubleValue(swUserPreferenceDoubleValue_e.swDxfMergingDistance, Value) = 0
                          ' End Point Merging - High quality DWG export
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDXFHighQualityExport, OnFlag) = False
                          ' Spline export options - Export all splines as splines
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfExportSplinesAsSplines, OnFlag) = True
                          ' Spline export options - Export all splines as polylines
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfExportSplinesAsSplines, OnFlag) = False
                          ' Multiple sheet drawing - Export active sheet only
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, swDxfMultisheet_e.swDxfActiveSheetOnly) = True
                          ' Multiple sheet drawing - Export all sheets to separate files
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, swDxfMultisheet_e.swDxfSeparateSheets) = False
                          ' Multiple sheet drawing - Export all sheets to one file
                          ISldWorks:: SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, swDxfMultisheet_e.swDxfMultiSheet) = False
                          ' Multiple sheet drawing - Export all drawing sheets to paper space
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfExportAllSheetsToPaperSpace, OnFlag) = False
                          'Do you want to export entities on all layers? <Yes/No>
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDXFExportHiddenLayersOn, OnFlag) = True
                          'Do not ask again
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDXFExportHiddenLayersWarnIsOn, OnFlag) = True
                          ' Use Solidworks Layers
                          ISldWorks:: SetUserPreferenceToggle(swUserPreferenceToggle_e.swDxfUseSolidworksLayers, OnFlag) = True
                          However, I can't seem to run the script - keep getting an error:
                          What's wrong here?
                          Full script below
                          Dim bRet As Boolean
                          Dim nErrors As Long
                          MkDir sPathName
                          Debug.Print ""
                          'Do not ask again
                              Shaun Jalbert
                              Please see my full code below.
                              I keep getting a compile error at:
                              Can anyone point out what's wrong?
                              Dim bRet As Boolean
                              Dim nErrors As Long
                              MkDir sPathName
                              Debug.Print ""
                              'Do not ask again
                                Deepak Gupta
                                You need to format the lines correctly.
                                For e.g. this line
                                should be
                                swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfVersion, 6
                                Please update the other lines correctly and it should work fine.
                                    Shaun Jalbert
                                    Thanks so much. Worked like a charm.
                                    Full corrected script in case anyone else ever needs it.
                                    Dim bRet As Boolean
                                    Dim nErrors As Long
                                    Dim UserPreferenceValue As Integer
                                    Dim OnFlag As Boolean
                                    MkDir sPathName
                                    Debug.Print ""
                                    swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfOutputFonts, 1
                                    swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfOutputLineStyles, 1
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfMapping, True
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDXFDontShowMap, True
                                    swApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swDxfMappingFiles, CustomMap
                                    swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfOutputNoScale, True
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfEndPointMerge, True
                                    swApp.SetUserPreferenceDoubleValue swUserPreferenceDoubleValue_e.swDxfMergingDistance, 0
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDXFHighQualityExport, False
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfExportSplinesAsSplines, True
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfExportSplinesAsSplines, False
                                    swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, True
                                    swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, False
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfExportAllSheetsToPaperSpace, False
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDXFExportHiddenLayersOn, True
                                    'Do not ask again
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDXFExportHiddenLayersWarnIsOn, True
                                    swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfUseSolidworksLayers, True
