7 Replies Latest reply on Jan 30, 2018 5:24 AM by Gabriele Sorrento
    C#: Mesh Export
    Gabriele Sorrento
      Hi guys,
      do you know a way to iterate over all objects of a document and get their mesh description (nodes, facets, hopefully color & transparency)?
      Thanks!!
        • Re: C#: Mesh Export
          Christian Chu
          Luke has created some C# tutorials and posted them on youtube
          I think you'd better start from beginning than jumping in and programming.
            Gabriele Sorrento
            Sorry, I have been watching his videos and I also read his blog but I cannot find exactly what I am looking for.
            I am not asking to post a solution but even a hint would be helpful.
              Gabriele Sorrento
              Thanks for your support. This is the solution I could find to get the meshes iterating over the assembly:
              if (nDocumentType == swDocumentTypes_e.swDocASSEMBLY)
                                  IAssemblyDoc swAssembly = null;
                                   swAssembly = (IAssemblyDoc)swModel;
                                  int n_comp = swAssembly.GetComponentCount(false);
                                  object[] comps = swAssembly.GetComponents(false);
                                  foreach (Component2 cp in comps)
                                      List<float> triangles = new List<float>();
                                      List<float> normals = new List<float>();
                                      Object[] aBodies;
                                      aBodies = (Object[])(cp.GetBodies2((int)swBodyType_e.swSolidBody));
                                      swModel.ClearSelection2(true);
                                      foreach (IBody2 swBody in aBodies)
                                          bool bSelected = swModelExtension.SelectByID2(swBody.Name, "SOLIDBODY", 0.0, 0.0, 0.0, true, 0, null, (int)swSelectOption_e.swSelectOptionDefault);
                                          IFace2 swFace = null;
                                          swFace = swBody.IGetFirstFace();
                                          while (swFace != null)
                                              int iNumEdges = swFace.GetEdgeCount();
                                              IEdge ff = swFace.GetEdges()[0];
                                              // TOPOLOGICALLY DISCONNECTED TRIS    <----------------------------------------
                                              int numtris = swFace.GetTessTriangleCount();
                                              float[] norms = (float[])swFace.GetTessNorms();
                                              float[] tris = (float[])swFace.GetTessTriangles(true);
                                              for (int t = 0; t < numtris ; t++)
                                                  triangles.Add(tris [i]);
                                                   normals.Add(norms [i]);
                                               swFace = swFace.IGetNextFace();
              now I have two issues:
              - the triangles are not topologically ordered (each triangle contains the coordinates of the three points rather than IDs of a node list)
              - the parts contained in the assembly seem to shifted on the origin of the assembly refsystem. I guess they contain the information of the related xform in the .Transform method, but when I apply it to the single body the tessellation coordinates seem not to be affected. Anyone knows a way to apply the transformation to the tessellation in order to place the components in the right way?
                  Jacob Corder
                  if you want the coordinates in the model which is exempt from ALL possible assembly transformations then you simply do this
                  Dim SwModel as modeldoc2 = CP.GetModelDoc2
                  Dim PDoc as partdoc = swmodel
                  Dim SwBodies as object = Pdoc.GetBodies2
                  loop on the bodies here
                  these tesselation points will be MODEL Based, NOT ASSEMBLY BASED.
                  if you need to do math transformations i would not use solidworks math class. i would use my own or
                  System.Windows.Media.Media3D Namespace
                  I would build an infrastructure of classes to accomodate all of this math.
                  Create TriangleClass, contains references to 3 points in the TesselationCollectionClass
                  Create a TesselationCollectionClass contains all triangles and points
                  triangle contains point0, point1, point2,and access to  TesselationCollectionClass
                  Point classes contains x,y,z in some form
                  TesselationCollection contains All Points in a list
                  TesselationCollection contains all triangles
                  TesselationCollection allows for Transformation Multiplication
                  in the tesselationCollection class you have a method MultiplyTransform(some transformation arguments)
                  execute the multiplication across all points.
                  all triangles will automatically be recalculated because they point to the  Point3D class
                  basically you are making a huge mathutility
                  the multimedia3D namespace contains all of the transformation math so you dont need to deal with it. its pretty easy to use with the transformations that solidworks gives you
                  The beauty of this is you will definately want to use Parallelism.
                  TASK::PARALLEL::FOREACH.
                  it could even be calculated using the graphics card if your tesselation point count gets to be too high. read up on CUDA Code if you haven't already
                  it will calculate it at a very fast pace.
                  and its by far the easiest thing to do.
                    Simon Turner
                    To answer your first question, an alternative way to tessellate an object is to use the ITessellation interface.
                    There is an example in the help - Tessellate a Body (C#)
                    Gabriele Sorrento
                    Thank you all for your replies
