This content has been marked as final.
Show 9 replies
Re: SIMMULATION ACCURACY
Shaodun LinJan 9, 2018 9:01 AM (in response to Meyron Samuel)
- Which result is bigger after the mesh size become smaller? Stress? Strain? Displacement?
- Could you upload a picture to show the boundary conditions?
Meyron Samuel Jan 9, 2018 9:11 AM (in response to Shaodun Lin)hi thanks for responding!
the smaller the mesh elements are, the bigger the stress is
Meyron Samuel Jan 9, 2018 9:28 AM (in response to Meyron Samuel)as you can see the max stress is over 10 MPA and the calculated answer is 9 MPA
Shaodun LinJan 9, 2018 9:23 AM (in response to Meyron Samuel)
Can you show the result with coarse mesh size?
Shaodun LinJan 9, 2018 11:24 AM (in response to Meyron Samuel)
I guess the max stress is due to stress concentration at the sharp edge.
Hand calculation probably does not consider the effect of stress concentration
Jon Dahlgren Jan 9, 2018 11:39 AM (in response to Shaodun Lin)A typical singularity as Shaodun describes.
Edit: To clarify, a singularity is a numerical error where the solution tends to infinity with increased mesh resolution. -
Meyron Samuel Jan 15, 2018 1:33 AM (in response to Shaodun Lin)thank you for your time and answers!
