What is the way to have different Global Variable values for each configuration? Because even though I gave a different Global Variable values for each configuration, it took up the default configuration values.
A window pop-ups but it has two separate question with one answer.
Yes I want to save changes to the current configuration but I do not want to switch to another configuration.
Maha,
To change the value for a Global Variable in different configurations, you need to tell SolidWorks that is what you want.
Right now you have told SolidWorks you want the same number for ALL configurations.
So, just select a different choice from the drop-down.
