9 Replies Latest reply on Jan 7, 2018 8:16 PM by Rob Edwards
    re: GetAll2 Method (ICustomPropertyManager)
    Rob Edwards
      It's my first time with the CustomPropertyManager and I'm just wondering is this right?
      I am inserting an envelope in an assembly and then making it virtual before I go in and change the custom properties.
      My complete code is below, but here's the relevant bit
      Debug.Print "Custom Properties"
          Set swCustPropMgr = swModel.Extension.CustomPropertyManager("Default")
          Dim Names As Variant
          Dim Types As Variant
          Dim Values As Variant
          Dim ResolvedValues As Variant
          Dim i As Integer
          With swCustPropMgr
              ls = .GetAll2(Names, Types, Values, ResolvedValues)
              Debug.Print "GetAll2 Status > Returned:"; ls
              Debug.Print " #", "Type", "ResolvedValue", "Value", "Name"
              Debug.Print String$(80, "-")
              For i = 0 To ls - 1
                  Debug.Print i + 1, Types(i), ResolvedValues(i), Values(i), Names(i)
              Next
          End With
      Why are all my resolved values = 2 ?
      from the help file
      Dim instance As ICustomPropertyManager
      Dim PropNames As System.Object
      Dim PropTypes As System.Object
      Dim PropValues As System.Object
      Dim Resolved As System.Object
      Dim value As System.Integer
      value = instance.GetAll2(PropNames, PropTypes, PropValues, Resolved)
      As a brief aside I wasn't certain how to go about doing this and tried various methods.
      I found that ActivateDoc3 reported an error if the file wasn't saved.  I didn't find this in the documenation.
      2016 SOLIDWORKS API Help - swActivateDocError_e Enumeration
      ActivateDoc3 Status > Errors: 8
      Anyway error or not, it still worked just the same, here's my code
      Thanks for looking
      Option Explicit
      Dim swAssem As SldWorks.AssemblyDoc
      Dim EnvelopeComponent As SldWorks.Component2
      Dim swDimension As SldWorks.Dimension
      Dim swCustPropMgr As SldWorks.CustomPropertyManager
      Dim ls As Long, lw As Long
      Dim bs As Boolean
          With swApp
              Set swModel = .NewDocument(DefaultAssTemplate, 0, 0, 0)
              bs = .RunCommand(swCommands_Save, "")
              Set EnvelopeComponent = swModel.InsertEnvelope(EnvelopeName, "", 0, 0, 0)
              swModel.ViewZoomtofit2
              bs = EnvelopeComponent.MakeVirtual2(False)
              bs = swModel.Save3(swSaveAsOptions_e.swSaveAsOptions_SaveReferenced _
                               , errors:=ls, warnings:=lw)
              Debug.Print _
                         ".Save3 Status > error:"; ls, "warning:"; lw
              Set swModel = .ActivateDoc3(EnvelopeComponent.GetPathName _
                                        , UseUserPreferences:=False _
                                        , Option:=swRebuildOnActivation_e.swRebuildActiveDoc _
                                        , errors:=ls)
              Debug.Print _
                            "ActivateDoc3 Status > Errors:"; ls
          End With
          Dim i As Integer
          With swCustPropMgr
              For i = 0 To ls - 1
              Next
          End With
      Private Function EnvelopeName() As String
          EnvelopeName = swApp.GetCurrentMacroPathFolder & "\" & "Default Table Top.SLDPRT"
      End Function
      Private Function DefaultAssTemplate() As String
          DefaultAssTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateAssembly)
      End Function
