Time to Vote on the Future of SOLIDWORKS!
Question asked by Alin Vargatu on Jan 5, 2018
Latest reply on Jan 23, 2018 by Jim Wilkinson
Just a quick heads up, if anyone is having difficulties to vote it could be because you are required to first vote on how the R&D resources should be allocated. Use this link for that: https://forum.solidworks.com/community/solidworks-world-2018-top-ten-list
After that no one should have difficulties voting.
These are my suggestions (actually most of them are my customers' suggestions, picked while brainstorming during advanced custom training courses). If you believe you would benefit from these enhancements, please vote on them. Equally important, please comment why you voted up or down on each idea.
Option for "Offset Surface" to offset all possible faces
Allow equations (including if/then statements) in defining custom properties
Add option to limit the Coincident Mate to the area of the face that is selected, for all types of faces
Add ability to project any type of entity (Face, Component(s), Body, Bodies on a Plane or a Surface, like we can do now with edges
BOM driven by Display States (get a list of all components visible in a drawing view)
Allow features to be edited from inside the Comments folder
Unbend any profile (tube, pipe, bent component) similar to the Sheet Metal Functionality
Enhance the Cut-List Table functionality to match a BOM Table functionality
Show BOM dependency to an assembly
Make the Selection Sets functionality consistent and expand it
Make patterns consistent across the board
Ability to automatically drive the colour of BOM rows, or change row font, based on custom properties or other user controlled criteria
New mate: Volume or Boundary Mate
New Mates: Distance Mate and Limit Mate between Components
Tool to quickly identify fillets on imported geometry
Allow equations in sensors
Also like these ones:
"Show Feature Dimensions" for Individual Features
Mates - Line Segment and Partial Circle Sketch Mates -
Import SolidWorks files of futur version into and older one with 3D interconnect.
Update Bounding Box of part from top assembly
Performance verses Image Quality and modern computers
Ability to assign a shortcut key or add a toolbar to every action in SolidWorks. Clean up the interface
Area of Shaded Sketch Contour
Model property to exclude from bill of materials
Ability to isolate a sketch
Ablity to view File Properties in eDrawings
Custom Mate in Motion Studies
Feature Recognition should use the "old" face ID
Up to Reference for Component Pattern in Assembly
"Background" Resolve option for Lightweight components
Improve Sketch Picture Menu
Add a "Selection Rule" to filter objects
Get the EPDM informations / properties into the assembly visualization window (checked out by, state, ...)
Graphical component preview during replace components
The coordinate systems of assemblies should have different color / form than of parts
Enhance Cavity command to Boolean subtract their Negative/False Body
Ability to replace all components in the current assembly only
Profile center mate: Allow to mate a line or point with the profile center
Coatings Feature
Ability to edit global variables direct from FeatureManager Design Tree
The ability to modify Global Variables without opening the Equation manager
Ability to use orientation of hole wizard holes in a pattern driven component pattern
Enhanced change documentation / history tracking in drawings
Ability to pass over construction lines when using the cut command in sketches
allow patterning (linear, circular, etc.) of Curves
Undo/Redo - Un-Limited/Un-Restricted
Make the user interface for the SR SPR and ER system User Friendly
Ability to select an existing sketch (containing points) to specify Hole Wizard hole positions
Add Bend Feature for Structural Members in Weldments
