I made a Sweep Cut with a solid body and got this annomally. Anyone know what happened? SW2016 SP3.0
Hi Brian,
Here is a version I did that managed to erase the abnormality..........
I am not sure as to why you created your sweep profile like you did? I basically just edited your revolve so that it included the .25 arc (your fillet) and then I deleted your fillet from the feature tree.
There doesn't seem to be an issue now...................
Part is attached............... SW2016 SP3
Dave.
Sorry but I have SW2017 and can't save to 2016 version. Just delete Fillet1, then edit Sketch2, delete the bottom horizontal line and replace it with a tangent arc for the full radius end. The tool solid (ball end mill) should not have the fillet added but instead have the arc included in Sketch2.
