I recently started to use Solidworks Routing Add-in with SW2017. It's pretty messy sometimes and not very intuitive but it's definitely disappointing when a warning doesn't show up to help a user fix or understand what's wrong.
Last thing I don't get it's why my example route (pics attached) has virtual pipes misaligned while the elbows have been put by the outer diameter after the bend radius have been automatically created. I tried to manually modified such radius ineffectively.
Somebody knows how to help or what's happening, please?
Stefano Tiburzi
Italy
Current sketch driving elbow
Note that arc end points are not inline with axis of elbow. Also bend radius elbow should be to the inside arc not the outside construction geometry. and bend angle was the opposite was too.
Fixed elbow
Use the attached elbow and you should be good to go. I also renamed it as i've found that SWx gets cranky with () in part names sometimes
