I am trying to use a design table to create a number of different configurations of a part that I found online. The dimensions I am interested in modifying are linked to 1) the offset distance of a reference plane (from the right plane) and 2) the distance of a Move Body command. I am not sure how to get these values to show up in the design table so that I can edit their values for different configurations.
Double click on the plane and select the dimension and cut and paste it into the table:
Or if you right click on the dimension and choose configure dimension:
and add a configuration:
Then Modify the dimension in one of the configurations:
Then SWX should prompt you to add it to SWX for you:
