I am trying to wrap a section around a part using a spline. The spline has to start at one diameter and end at a smaller diameter
any ideas?
any ideas?
I don't have a model. That is what I am trying to create I have a circular part, with draft and want to wrap a constant cross section around it while progressing back from front of part
A connector attached to the cable. OD of connector is 22mm, will need to be constant section geometry wrapped at least 40MM long axially around connector and cable whose diameter is 2.5mm
like tape wrap.
Can you take a screenshot of what you have so far? It's hard to picture what you're trying to do without a little more information. From what I can gather, it sounds like a sweep with guide curves or maybe using a helix with a draft angle is what you're after.
Please make screenshot or attach model
