Hello everyone,
I have a customer that will vacuum mold a two-piece cover for a drawer assembly. He is requesting a shell of the assembly. The assembly is pretty completed some areas and file size 60 to 80 meg after I strip it down. Any suggestions on how to go about this if possible?
You may be able to save the assembly as a part. Open that part and make a block encasing it using Multi=bodies. Try either the join command or intersection to subtract the original part from the block. The hollowed-block could then be shelled to give the clam-shell pack.
