so I have a customer part and I can not offset the surfaces at 0.00 so I can do my die design how do I work around this? some of the face I can not even pick I need to start this design now and I am not sure how cause I can not do anything, Please help.
Run import diagnostic. See where your model has errors. Now cut extrude the affected area out and save it as 1.x_t.
Then edit the cut extrude and select "flip side". That should give you the cut out body. Save it out as 2.x_t.
Import the file and run import diagnostics. Fix the errors. If it works then you should have on body without errors and another with.
Now you can fix the faulty section without having to work in a large component. Then save out the fixed body.
Finally import both bodies and merge. Now you should have a working model.
Use Import Diagnostic after import part is modified ... is also of interest if you happen to find errors after you have edited the dumb solid.
Elmar
