API MassProperty object does not use assigned coordinate system
Question asked by Andy Abate on Jan 4, 2018
Latest reply on Jan 4, 2018 by Andy Abate
Hi there,
I am writing a macro for SW2017, and I have two problems:
1) For some reason, API MassProperty objects do not use the assigned coordinate system after SetCoordinateSystem() returns True.
2) Mass properties do not update until I open the "Mass Properties" GUI.
With an open part file, I use ModelDocExtension::CreateMassProperty() to create a new MassProperty object. I use ModelDocExtension::GetCoordiniateSystemTransformByName(), the coordinate system is found, and I checked the ArrayData to ensure it is the correct transform. MassProperty::SetCoordinateSystem() returns True, that it set the coordinate system for the MassProperty object.
BUT, when I call CenterOfMass and GetMomentOfInertia(), they are still relative to the default coordinate system! I have checked everything I can think of, and it seems like SetCoordinateSystem is failing somehow.
The documentation says CreateMassProperty() always uses up-to-date mass information, but that does not seem to be the case. Saving and rebuilding have no effect on new MassProperty objects; only opening the "Mass Properties" GUI updates new MassProperty objects.
What am I missing, and how can I get the expected behavior from SW?
Andy
EDIT:
     Well, I found the issue: Overriding mass properties in the SW GUI messes everything up. I unchecked that and everything works the way it should.
     So, now I guess this is a bug report.
     If anyone knows a good way to override mass properties in a way that does not break everything, that would be nice!
Full Code:
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swModelExt              As SldWorks.ModelDocExtension
    Dim swMass                  As MassProperty
    Dim Ic                      As Variant
    Dim c                       As Variant
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
        MsgBox "No active doc."
        Exit Sub
    Set swModelExt = swModel.Extension
    Dim fso As Object
    Set fso = CreateObject("Scripting.FileSystemObject")
    Dim ofile As Object
    Set ofile = fso.CreateTextFile(swModel.GetPathName() + "-inertia.txt")
    If ofile Is Nothing Then
        MsgBox "Cannot create output file."
        Exit Sub
    Set swMass = swModelExt.CreateMassProperty()
    ' Set coordinate system
    If swMass.SetCoordinateSystem(swModelExt.GetCoordinateSystemTransformByName("Body-Frame")) = False Then
        MsgBox "Must have a 'Body-Frame' coordinate system."
        Exit Sub
    ' Get mass properties
    Ic = swMass.GetMomentOfInertia(swMassPropertyMoment_e.swMassPropertyMomentAboutCenterOfMass)
    c = swMass.CenterOfMass
    ' Write to file
    Dim fmt As String: fmt = "0.0000e+00"
    ofile.WriteLine ""
    ofile.WriteLine "m  =  " & Format(swMass.Mass, fmt) & "; % kg"
    ofile.WriteLine "c  = [" & Format(c(0), fmt) _
                      & " " & Format(c(1), fmt) _
                      & " " & Format(c(2), fmt) & "]; % (x,y,z) mm"
    ofile.WriteLine "Ic = [" & Format(Ic(0), fmt) _
                       & " " & Format(Ic(4), fmt) _
                       & " " & Format(Ic(8), fmt) & "   % (Ixx,Iyy,Izz) kg.m^2"
    ofile.WriteLine "      " & Format(-Ic(1), fmt) _
                       & " " & Format(-Ic(2), fmt) _
                       & " " & Format(-Ic(5), fmt) & "]; % (Ixy,Ixz,Iyz) kg.m^2"
    ofile.Close
