I have created a part using surfaces. basically creating two flat surfaces in perpendicular planes and then connecting them with a lofted surface that is tangent to both faces. I would like to make this a sheet metal part. I believe it can be created without having to stretch the metal, but I don't know any way to make this using the sheet metal options. The lofted bend isn't working because I don't see any options of making it tangent. I can't use surface flatten because I don't have Premium. Thanks!
I take it this is what you don't want.. Am I correct.. You basically want a ribbon that unrolls?? I can't figure out a way to do that quite yet.
