Hi folks
I'm currently having problems with two separate parts that have been extruded from the same sketch. As one must fit into the other, every time I've tried resize one of them smaller to fit, the other has annoyingly updated to the new dimension and thus won't fit when I go to assemble. I surprising can't find anything on how to turn off the auto update between these two related parts.
Thanks in advance for your help!
Stop using the same sketch to do the 2 different extrudes. If you want to use modified geometry of the first sketch, offset the first in a second sketch. This uses the first geometry but has a slightly different relationship.
