Is it possible to show selected bodies only (in drawing view) in a weldment cut list, without having to manually exclude each body from the cut list?
You should have the option to select a body to display when you have picked your part to be inserted into the drawing. Select "Select Bodies..." and then pick the body of the weldment you want to display. Standard views work the same as they would if it where the full part there so keep that in mind when you are needing a certain "side" view.
Deepak Gupta wrote:
Create a config with required bodies and then show the cut list for that configuration.
To expand on Deepak's suggestion in your configuration use the delete bodies to remove all of the unwanted bodies from your weldment. This will give you a cutlist of only the parts you want to detail or information on.
yep study the insert drawing view section of the drawing when doing a weldment you may see something that says select body try that and see what it does for ya.
