check out script is to slow
Question asked by Lasse Nielsen on Jan 2, 2018
Latest reply on Jan 3, 2018 by Lasse Nielsen
Hello forum,
I'm trying to create a custom script, that allows me to clean up some data on old data cards and old custom properties
So far I have created the following - almost working script. The problem is that PDM is to slow to check out the file in question, causing an error to occur when writing data to the data card. The error occurs at "pEnumVar.SetVar". How can I fix that?
Best
Lasse
Option Explicit
Dim pdmVault As Object
Dim strFullPath As String
Dim strFolderPath As String
Dim strFileType As String
Dim intFileType As Integer
Dim Errors As Long
Dim Warnings As Long
    strFullPath = "<Filepath>"
    strFolderPath = "<Path>" & "\"
    strFileType = LCase(Right(strFullPath, 6))
    Select Case strFileType
        Case "sldprt"
            intFileType = 1
        Case "sldasm"
            intFileType = 2
        Case Else
            End
    End Select
    Set pdmVault = CreateObject("ConisioLib.EdmVault")
    pdmVault.LoginAuto "LQN-Sandbox", 0
    Dim folder As Object
    Set folder = pdmVault.GetFolderFromPath(strFolderPath)
    Dim file As Object
    Set file = pdmVault.GetFileFromPath(strFullPath, folder)
    Dim pEnumVar As Object
    Set pEnumVar = file.GetEnumeratorVariable
    If False = file.IsLocked Then
        file.LockFile folder.ID, 0
    pEnumVar.SetVar "RevisionNote", "Default", "Test", False
    pEnumVar.Flush
    If True = file.IsLocked Then
        file.UnlockFile 0, "Checked in by Macro"
