Hi, I want to make the numbered text on this part to be wider. #1 was done as an example. What would be the easiest way in makin these numbers more wide? the numbers are sketched using spline.. Ive also attached the part file for you guys to see..
I don't have time to open your Part right now, but why did you create the numbers with splines and lines instead of using Sketch text? Then you could have changed the font to adjust the size?
I initially tried using the sketch text and it did not work for me. However, I tried using that feature again and then adjusted the font according to my preferences. Thank you.
