4 Replies Latest reply on Jan 2, 2018 4:45 PM by Elmar Klammer
    loop macro
    Faez Alkadi
      I have never worked on macro before and would love to know if there are some resources or videos to help me learn. I want to build a macro that offset surface of a body for i number of times and save every single offset as a separate IGES file format.
      In this macro I wish to be able to input offset distance (d) which increases with same amount every loop and number of desired loops (i).
      And get output, i number of files for the offseted surface in IGES format named from 1 to i.
      For example:
      First offset file name is 1.IGS.
      Second offset file name is 2.IGS.
      and so on ....
      Last offset file name is 100.IGS. (if i =100)
      All in the same folder in my PC.
      I wish to use this micro to offset any surface one any solid part. After I select the surface that i want to offset, I just run the macro and determine (d) and ( i) and just run it.
      Thank you so much
        • Re: loop macro
          Peter Kennedy
          Keith Rice has a website with some good information about learning solidworks API. www.cadsharp.com
          • Re: loop macro
            Elmar Klammer
            Hi Faez
            Check How to delete overlapping solids?  it does part one. Use macro below to find offset feature. Look api for save as code.
            you are done.
            ' Preconditions:
            ' 1. A part document is open in SolidWorks.
            ' 2. Open the Immediate window.
            ' 3. Run the macro.
            ' Postconditions: Examine the Immediate window for
            ' the position and names of the features in the
            ' FeatureManager design tree in reverse
            ' chronological order.
            Option Explicit
            Dim Part As SldWorks.ModelDoc2
            Dim theFeature As SldWorks.Feature
            Dim featCount As Long
            Dim featName As String
            Dim i As Long
                Set Part = swApp.ActiveDoc
                featCount = Part.GetFeatureCount
                For i = featCount To 1 Step -1
                    Set theFeature = Part.FeatureByPositionReverse(featCount - i)
                    If Not theFeature Is Nothing Then
                        featName = theFeature.Name
                    Debug.Print "Feature " + Str(i) + " is " + featName
                Next
                Set Part = Nothing
