Insert a sketch for user to edit from event handler
Question asked by Rob Edwards on Dec 31, 2017
Latest reply on Dec 31, 2017 by Deepak Gupta
Hi Forum
I'm using the holidays to invest in a bit of API study, it's great! -  no ones bothering me
I'm currently looking at using events
Specifically in this case I am trying to create a new sketch when the user adds a configuration.
I would then like to pass control back to the user so they can create the sketch
I will then pick up the new sketch has been created and do some more stuff
At first it appears to work fine, however there is something wrong.
The sketch entities are not displayed and the sketch is empty - eg a rectangle
It gets added to the tree, but will be deleted if it is again edited
Here's my debug.print that shows somethings working
swNotifyConfiguration       A
swNotifyFeature             Sketch3-A     ProfileFeature
swNotifyConfiguration       B
swNotifyFeature             Sketch3-B     ProfileFeature
swNotifyConfiguration       C
swNotifyFeature             Sketch3-C     ProfileFeature
and heres the code,,, macro attached.  I use 2016
The macro selects a face called "Blank Face" , so I also attach a simple sample file
'Part_Events_Study1
Option Explicit
Public swapp As SldWorks.SldWorks
Dim swPartEvents As Class1
    Set swapp = Application.SldWorks
    Set swPartEvents = New Class1
    swPartEvents.Init
'Class1
Option Explicit
Public WithEvents swPart As SldWorks.PartDoc
Public Sub Init()
    Set swPart = swapp.ActiveDoc
Public Function swPart_AddItemNotify(ByVal EntityType As Long, ByVal itemName As String) As Long
     Select Case EntityType
            Case swNotifyConfiguration
                With swPart
                    Debug.Print "swNotifyConfiguration", itemName
                    Dim swFace As SldWorks.Face2
                    Set swFace = .GetEntityByName("Blank Face", swSelFACES)
                    swFace.Select4 False, Nothing
                    '.FeatureManager.EditRollback swMoveRollbackBarToAfterFeature, _
                                                  "Folder1"
                    With .SketchManager
                        .InsertSketch (True)
                        .ActiveSketch.Name = .ActiveSketch.Name & "-" & itemName
                    End With
                End With
            Case swNotifyFeature
                Debug.Print "swNotifyFeature", itemName, _
                            swPart.Extension.GetLastFeatureAdded().GetTypeName2
                'TODO catch when sketch is added
     End Select
End Function
Public Function swPart_DestroyNotify2(ByVal DestroyType As Long) As Long
     Set swPart = Nothing
End Function
