Hello
After inserting the models of parts into an assembly from Solidworks Electrical component tree, Solidworks adds that part into the feature tree. When this is done, the name of the part in the feature tree is a combination of name given to the component and a random number generated by Solidworks Electrical.
When a component is renamed in Solidworks Electrical Schematics, the name of the component updates in the component tree in Solidworks Electrical 3D. But, the name of the component in the feature tree doesn't update.
For example, in the below screenshot, 'MCP X32 18' is the initial component name given in Solidworks Electrical Schematics. So, the name of that part becomes MCP X32 18|83862 in Solidworks Electrical 3D. When I change the name of that component from 'MCP X32 18' to 'X1' in Solidworks Electrical Schematics, the feature tree in Solidworks Electrical 3D doesn't update to X1|83862. Is there a solution to this issue? The naming of the components in Solidworks Electrical component tree need to match the naming of parts in feature tree in order to avoid confusion.
Hello Saju Sam,
Which version of the software is used?
If it's a 2017 version, that's the problem.
It has been proved to be a bug.
SPR# 1059177 '3D part name keep as components mark instead of changing back to 3D model name after dissociate electrical components with 3D model, meantime cannot change to components mark after associate 3D model with electrical components'
Hope that makes sense!
BR,
Nicky
