Good morning.
The problem is the following:
- I export a slddrw to DWG in version 2000/2002.
- Solidworks 2016 exports it without problems, apparently.
- When opening the exported dwg, everything seems correct. If you move a drill, or a view, autocad changes the metric threads by drills (M5 => Ø5)
This is very problematic, since my suppliers (CAM, laser, waterjet) use the DWG drawings for the manufacture of parts. This problem causes that all the pieces that I receive are defective.
I have never had this problem with other versions of solidworks, it only happens to me in my current version (SW 2016 SP.4)
I have tried to change the export version (R12, R14 ....) but it does not solve the problem
Is it a SW2016 error or is it a configuration problem?
A greeting
Buenos dias.
El problema es el siguiente:
- Exporto un plano a DWG en versión 2000/2002.
- Solidworks 2016 lo exporta sin problemas, aparentemente.
- Al abrir el dwg exportado, todo parece correcto. Si mueves un taladro, o una vista, autocad cambia las rosca metricas por taladros (M5 => Ø5)
Esto es muy problematico, ya que mis proveedores (CAM, laser, waterjet) usan los planos DWG para la fabricación de piezas. Este problema provoca que todas las piezas que recibo son defectuosas.
Nunca habia tenido este problema con otras versiones de solidworks, solo me ocurre en mi actual versión (SW 2016 SP.4)
He intentado cambiar de versión de exportacion (R12, R14....) pero no soluciona el problema
¿Es un error de SW2016 o es un problema de configuración del mismo?
Un saludo
Diego,
If these files are flat pieces, why not just export dxf files from the model itself? I don't know of any CAM packages that can't work with dxf files. Exporting drawing files could open one up to all kinds of problems....scaling being one of them....
Bob
