I'm using VBA to change property fields in a drawing. I just upgraded my computer which is now running Office 2013 and my code doesn't work anymore. I get an error message of "Compile error: Can't find project or library" when I try to execute the following code. Additionally, the text "swCustomInfoText" is highlighted by the debugging program.
Sub ChangeProperties()
Dim swApp, Part As Object
Dim boolstatus, retval As Boolean
Set swApp = CreateObject("sldworks.application")
swApp.Visible = True
FilePath = DirectoryPath & "\" & DrawingFileName
swApp.OpenDoc FilePath, 3
Set Part = swApp.ActiveDoc
retval = Part.DeleteCustomInfo2("", "DrawnDate")
retval = Part.AddCustomInfo3("Default", "DrawnDate", swCustomInfoText, VBA.Format(VBA.Date, "m/d/yy"))
boolstatus = Part.EditRebuild3()
Sounds like some of your SW references are missing. See if your macro is referencing SOLIDWORKS (version) Constant type library.
