So I have this problem where whenever I change the tolerance of a dimension to be 'Basic' (Boxed dimension) it will change the text within the box to Chinese characters. On the drawing document attached you can move the dimension about and it will sometimes change to the dimension which should read as "100" but if you try to export to PDF or print it it will always print as the symbols, even if it's displaying as the correct text on the screen at the time. I have attached a screen shot of an example of what I'm getting and also a sample document (Drawing and Part) to see if anyone can figure it out? Thank you.
It opens up and show fine for me. I'm just thinking that your font (ISOCPEUR) file may be corrupted. So check on a different machine if you can and it this works fine on other machine, then copy the font from other machine to your machine and check.
