hi, I have a multi body part that has some weldments, imported geometry and sheet metal in it. It was working fine and has a control q rebuild time of 2.8 seconds. The problem is when I modify a flange or any other modification it hangs and can take several minutes to re build and in some cases crashes,! I am a relatively new user so any advice greatly Recieved. ..
Hi Pete,
I realise you probably want an answer to your problem straight away but there are numerous reasons this could be happening and without the part or assembly files to look at everyone would be just clutching at straws.......
Please read Some very important steps if you are a NEW FORUM USER.... so that you get the most appropriate help you can.
Dave.
