Hello, I have made a copy of the ANSI standard, so that I can
modify it for company use. We have our own standard when it comes
to clearance holes and c'bore holes. In SW '06, I was able to
modify the data base, to change the diameters of the clearance
holes, as well as the c'bore diameter and depth. We have now
upgraded to '09 and I am no longer able to find where I can change
the c'bore sizes. Clearance holes are available to edit, but I do
not see where the data is located for the c'bore holes. Any idea on
where to find this? Thanks in advance for any help.
Chris
Chris
It takes a while to populate the screen with available configurations, but when that is done, under the "Standard Properties" section of the screen, pick "Size". The counter bore information is in that table.
I have made a new standard and modified the size table but I an having trouble figuring out what the values control.
I can see that the hole sketch changes when I make a change in the table. But the tap drill depth is never right. There are also more values in the table then are needed for the hole's sketch.
How do I know what to set vaules in the table to?
There seems to be no way to control the drill depth.
