I would like to know how to read and edit feature properties
Question asked by Steve Anderson on Dec 21, 2017
Hello:
I have written/modified this code, and basically it traverses through the features.  I have been able to programmatically isolate the feature I wish to edit.  It is at the bottom of TraverseNode2 where I need help.
1.  In the selected feature, under "Standard:" I need to reload the static value "_WMI Profiles_"
2.  In the selected feature, under "Type: Configured Profile" (determined as node.Text), I need to add the value from my array and append the static value " - Configured" to it.
3.  In the selected feature, under "Size:" I need to first read (this can be done earlier on), and then repopulate the same information.
4.  Finally I need to check ok.
In the manual world, this is the only way I have found to add two properties to the cutlist properties.  The information already exists, but is just not there until this is done.
The goal will be to automate this in all parts, to eliminate the pain of doing it manually for thousands of parts.  For questions 1-3 above, I just do not see any API calls to accomplish these things.
See attachment...
Thanks!
        If (displayNodeInfo) Then
            ' Compare Contents of node item where TraverseLevel = 1 and contains the array information
            Debug.WriteLine(TRAVERSELEVEL & ": " & node.Text)
            For c As Integer = 0 To AL_WELDMENTPROFILEFILES.Count - 1
                Debug.WriteLine(AL_WELDMENTPROFILEFILES(c))
                ' Check if weldment profile is contained in feature name
                If TRAVERSELEVEL = 1 Then
                    If InStr(node.Text.ToLower, AL_WELDMENTPROFILEFILES(c).tolower) <> 0 Then
                        Debug.WriteLine("Feature Match: " & node.Text & ", " & AL_WELDMENTPROFILEFILES(c))
                        Dim cx As Integer = c
                        ' Edit Feature
                        ' 1. Reload --> '_WMI Profiles_'
                        Dim StandardProfile As String = "_WMI Profiles_"
                        ' 2. Select Type --> AL_WELDMENTPROFILEFILES(c) & " - Configured'
                        ' Get full path object
                        Dim ConfiguredProfile_FullPath As String = AL_WELDMENTPROFILEFILES_FULLPATH.Item(cx)
                        Debug.WriteLine(ConfiguredProfile_FullPath)
                        ' 3. Select Sized --> Must be read in prior to being specified again.Helo:
            Next
    Private Sub cmdTraverse_Click(sender As Object, e As EventArgs) Handles cmdTraverse.Click
        Dim swPart As ModelDoc2 = swApp.ActiveDoc
        ' Properties Variables
        Dim swCpm As CustomPropertyManager = swModel.Extension.CustomPropertyManager("")
        Dim GetNames() As String = swCpm.GetNames
        Dim theval As String = ""
        Dim thevalres As String = ""
        ' Create arraylist of SLDLFP files located in 'C:\Sackett-Waconia\Master Documents\SOLIDWORKS TEMPLATES\weldment profiles\_WMI Profiles_'
        ' ENHANCEMENT: Obtain progran folder programatically
        BuildArrayList(AL_WELDMENTPROFILEFILES, "C:\Master Documents\SOLIDWORKS TEMPLATES\weldment profiles\_WMI Profiles_")
        BuildArrayList_FullPath(AL_WELDMENTPROFILEFILES_FULLPATH, "C:\Master Documents\SOLIDWORKS TEMPLATES\weldment profiles\_WMI Profiles_")
            Debug.WriteLine(c & " of " & AL_WELDMENTPROFILEFILES.Count & ": " & AL_WELDMENTPROFILEFILES(c))
        Next
        ' Profile Variables
        Dim swSelectionManager As SelectionMgr = swPart.SelectionManager
        Dim featureManager As FeatureManager = swPart.FeatureManager
        Dim rootNode As TreeControlItem = featureManager.GetFeatureTreeRootItem()
        If Not rootNode Is Nothing Then
            MessageBox.Show(rootNode.ToString)
            TraverseNode2(rootNode)
        MessageBox.Show("Done.")
    Private Sub BuildArrayList(ByVal al As ArrayList, ByVal Folder As String)
        Dim Files As String() = Directory.GetFiles(Folder)
        Dim FileName As String
        For Each FileName In Files
            ' Return FileName without path
            al.Add(Path.GetFileNameWithoutExtension(FileName)) ' GetFileNameWithoutExtension also removes the path!
        Next
    Private Sub BuildArrayList_FullPath(ByVal al As ArrayList, ByVal Folder As String)
            al.Add(FileName)
        Next
    Private Sub TraverseNode2(node As TreeControlItem)
        Dim childNode As TreeControlItem
        Dim featureNode As Feature
        Dim componentNode As Component2
        Dim nodeObjectType As Long
        Dim nodeObject As Object
        Dim restOfString As String
        Dim indent As String
        Dim i As Integer
        Dim displayNodeInfo As Boolean
        Dim compName As String
        Dim suppr As Long, supprString As String
        Dim vis As Long, visString As String
        Dim fixed As Boolean, fixedString As String
        Dim componentDoc As Object, docString As String
        Dim refConfigName As String
        displayNodeInfo = False
        nodeObjectType = node.ObjectType
        nodeObject = node.Object
        Select Case nodeObjectType
            Case swTreeControlItemType_e.swFeatureManagerItem_Feature
                displayNodeInfo = True
                If Not nodeObject Is Nothing Then
                    featureNode = nodeObject
                    restOfString = "[FEATURE: " & featureNode.Name & "]"
                Else
                    restOfString = "[FEATURE: object Null?!]"
            Case swTreeControlItemType_e.swFeatureManagerItem_Component
                    componentNode = nodeObject
                    compName = componentNode.Name2
                    If (compName = "") Then
                        compName = "???"
                    suppr = componentNode.GetSuppression()
                    Select Case (suppr)
                        Case swComponentSuppressionState_e.swComponentFullyResolved
                            supprString = "Resolved"
                        Case swComponentSuppressionState_e.swComponentLightweight
                            supprString = "Lightweight"
                        Case swComponentSuppressionState_e.swComponentSuppressed
                            supprString = "Suppressed"
                    End Select
                    vis = componentNode.Visible
                    Select Case (vis)
                        Case swComponentVisibilityState_e.swComponentHidden
                            visString = "Hidden"
                        Case swComponentVisibilityState_e.swComponentVisible
                            visString = "Visible"
                    End Select
                    fixed = componentNode.IsFixed
                    If fixed = 0 Then
                        fixedString = "Floating"
                    Else
                        fixedString = "Fixed"
                    componentDoc = componentNode.GetModelDoc
                    If componentDoc Is Nothing Then
                        docString = "NotLoaded"
                    Else
                        docString = "Loaded"
                    refConfigName = componentNode.ReferencedConfiguration
                    If (refConfigName = "") Then
                        refConfigName = "???"
                    restOfString = "[COMPONENT: " & compName & " " & docString & " " & supprString & " " & visString & " " & refConfigName & "]"
                Else
                    restOfString = "[COMPONENT: object Null?!]"
            Case Else
                    restOfString = "[object type not handled]"
                Else
                    restOfString = "[object Null?!]"
        End Select
        For i = 1 To TraverseLevel
            indent = indent & "  "
        Next I
                        ' Edit Feature
            Next
        TRAVERSELEVEL = TraverseLevel + 1
        childNode = node.GetFirstChild()
        While Not childNode Is Nothing
            TraverseNode2(childNode)
            childNode = childNode.GetNext
        End While
        TRAVERSELEVEL = TRAVERSELEVEL - 1
