This content has been marked as final.
Show 3 replies
Re: Another problem in assemblies
Walter Fetsch Dec 20, 2017 12:50 PM (in response to Radu Balan)Radu, it would be much easier to help if you would pack and go your assembly and post it here.
Radu Balan Dec 20, 2017 3:33 PM (in response to Walter Fetsch)Thanks for your fast answer.
I attached the zip packed and go like you said.
ASS - H - Final assembly.zip 1.8 MB
Walter Fetsch Dec 20, 2017 4:53 PM (in response to Radu Balan)I can see that you're trying to overconstrain your assembly. Both the pinion gear and the trunion box are fully constrained in translation (they can rotate, but cannot move). If you try to constrain the pinion's axis to the axis of the post on the trunion box, it will overconstrain the system, since neither component is free to translate. Instead, add a parallel constraint to the trunion box and it will align with the pinion.
