Is there a way to set sheetmetal thickness of a base flange to the value of an offset dimension?
I don't want to have to set up a design table or global variable but associate the dim in sheet metal parameters to the 5mm offset dim that other components will be referenced from. I input "=" and click the sketch dim and no love.
I tried to get Alex's method to work but it just wouldn't. May be a setting??.. What I did was to sketch the profile for the base flange, did the offset (construction) and selected base flange. At this point it doesn't matter what the thickness is,, just need to establish the global variable. Then made the dims show ( right click Annotations, show feature dims). Then did an (right click on dim) unlink value on the thickness dim. Then linked the two dims to drop down arrow thickness) FYI.. I had tried to link the two without unlinking the thickness dim but it will not allow that.
Then a rebuild. Then change the sketch offset dim to whatever.
Rebuild.
You can now change that value with the sketch offset. The original thickness dim.. Or in the sheet metal property manager.
