JBJohn Boire19/12/2017
So, here is my problem.
I create a new file, select a template and the file gets created with the right format. Everything is good so far. However when I create a new sheet the format cannot be found. (Error message: "The sheet format could not be located")
My file path is correct, I have tried reloading the sheet format on the first page and then adding sheets, I can manually find the .slddrt file and when hit okay and the Sheet Format/Size window pops up I can hit browse and it shows up right away.
When I browse for the template and load it in there is no problem but when you have to do that for every single sheet in a 10-40 sheet file it can get rather annoying and really interfere with workflow, especially seeing as this is a new problem (We recently restructured our drive)
Is this perhaps a naming issue? There are 3 other sheet formats saved in the same location, is that a potential cause?
Ref for things I have tried already:
https://www.javelin-tech.com/blog/2017/05/solidworks-sheet-format-location-error/
SolidWorks Templates & more » Blog Archive » 99% of all drawing templates are missing this setting
Any ideas?
