I need all holes cut on side A and B. How can I kill two birds in one stone?
I believe it will take another operation:
Cheers,
Kevin
Hi Kevin,
Nice! It works! Thank you
You're welcome, I'm glad it helped.
I forgot to mention to make the 45° as a midplane (by selecting the leg faces) for the easiest plane construction.
If you are using Hole Wizard you can create the hole locations on two different surfaces using a 3D sketch. Depending on how you have you part modeled you can also use a circular pattern.
Cheers,
Kevin
