Hello All,
How can i add watermark to 3d model/assy in 2018.
Regards,
Kalpesh
Here I have my Watermark set as a Custom Property in the Part or Assembly File as "Watermark" - then in the drawing I typed in $PRPSHEET:"Watermark" as a note. You can adjust the type and font size.
Hello John,
Thanks for reply. The watermark will be visible in the model once set as custom property? It would be useful if you have any example.
If it just needs to be visible in the model then just add a note...
Hi Kalpesh,
In the SOLIDWORKS help, they also simply add a note and then set this to be a watermark (see image below)
Hello Ian,
The problem is step 2 not visible in sw hence I am trying to get different solution.
If it's just the notes area that isn't visible, you can add one in by right clicking on the notes > Insert Notes Area (image below)
