I coped my w-beam and it's 90 degrees, how do I cope it with a radius? I used the indent command to do the cope.
Tim Muir - You have to "Edit" the component, which you can do while you're working in the assembly level.....
You could create a Block and use that in your cut sketch or just add a radius..
