I am making a fan blade and I wanted to generate a flat pattern of it to compare to the original blade that I have. Is there a way to make a flat pattern from a curved part?
Here is a link to the part.
https://dl.dropboxusercontent.com/s/hq6um9k5xiw00co/fanblade.SLDPRT?dl=0
Timothy,, here is one that is converted. No flat area Just reordered. Roll up the bar in the feature tree under your Boss-Extrude1 then do an Insert bends. Roll the bar back down and fix up your cut extrude. You probably will want to do a normal cut with these since it is sheet metal.
