Maha Nadarasa wrote:
I wish to know which type of components must exclude.
It is very difficult to advise you. Normally I would say exclude fasteners. The problem is you may have a 5/16-18 screw in a 1/4-20 tapped hole. You would want to catch that. The problem is if you have a lot of fasteners, your interference list will be long.
Trial and error is your best teacher. Start with excluding nothing. Then try excluding something and see what happens (will you miss something important).
Good luck.
You are permitted to use engineering judgement and decision making techniques.
For example,
You have an o-ring that gets deformed in the real world assembly.
But in the virtual assembly you do not take the time to create two configurations - OOTB purchased condition and installed condition.
You just use the OOTB torus geometry as purchased and therefore get an indication of Interference Detection from SolidWorks.
Problem: What do I do? Do I incur the cost of modeling a compressed configuration for the assembly or do I make an informed engineering decision to ignore the Interference Detection because I fully understand the problem and understand that this particular interference is not a real issue in the real world assembly?
Now for some people - this problem would be like a ringing phone - they can't help but answer it.
For others, they know that they do not have to answer every ringing phone.
Hi Maha,
Simply exclude any components that you don't want the test to examine.
Dave.
