Looking for a generalized gauge and sheet metal bend table for Aluminum. We are not a fab shop, but I make all my own sheet metal parts and send out the drawings for Fabrication.
Searched google for information, and though I can find the gauges I have not been lucky enough to find the bend radius and the k-factors. Does anyone have anything they could share?
I prefer to use gauge tables instead of bend tables.
See my reply in this recent post: sheet metal properties
You should have a sample steel gauge table (Excel file) that came w/SW somewhere in one of SW install paths.
Copy it and edit it for aluminum gauges.
You can find aluminum gauge listings on the Internet.
Once you've populated this file with all (most) gauges, contact your fab houses to see what gauges they stock.
Copy the original gauge table and in the copy, delete the gauges your shops don't normally carry.
This will keep your gauge dropdown list short and limited to what's mostly available.
You can, at any time, change the gauge table to another file and select another guage (or another material).
As stated above, check with the fab shops you deal with to see what the nose radii are for their in-house tooling (standard or custom).
Enter these into the radius column. The radii need not be in numerical order, just separated by semicolons.
If you have a default radius in mind, enter that value first for each gauge.
If there's a second favorite radius, put it as the second number.
Probably best to enter any other remaining radii in numerical order.
The k-factor shown is for all gauges, but can be overwritten in the part.
Because of this, you may need to have multiple aluminum files so you're not having to override K when the aluminum alloy changes.
5052 bends a lot easier than 6061 and 6061 with generally require larger nose radius tooling to avoid tearing on the outer radius, so perhaps make 6061's default radii larger.
It is true about the general rule to keep the inner radius at least the gauge thickness, but metal is formed with real tooling not theory.
So you can bend to the tooling nose, usually as air bending, but if the nose is small enough, it'll be coining.
Keep the capabilities of your fab houses in mind while you model.
Also keep in mind that sheet metal is an art and you may not get an exact response to some questions, if the questions (directly or indirectly) ask about the ingredients in the secret sauce.
And develop a good working relationship with them for minimal costs and smooth projects.
Lastly, they know what's feasible so accept all advice with grace as it's for your benefit.
I hope this helps,
Kevin
