I have a macro feature in my drawing document. I use it to access custom properties and taking some actions according to their values
When I use main sub when inserting macro feature, there is no problem but after reopening the document it gives an error. I am guessing that main sub doesn't work at reopening. Is macro feature not supposed work like normal macros?
I tried to add some key statements to rebuild function like
Set swmodel = swApp.ActiveDoc
Set swcust = swmodel.Extension.CustomPropertyManager("")
I am not sure this is good coding, I normally don't enter these in any function when working with macros
But still there happens to be an error. If I ignore that error everything seems fine. This is because I thought main sub might be not working as should be in order. I tried writing On Error Resume Next but no avail
Am I missing something? Should I return some values at swmRebulid?
