CCColt Carson13/12/2017
I am getting the incorrect flat pattern for the attached sheet metal part. I am using sw2017 sp5.
-Could anyone confirm this part works in another service pack?
-Is there another way to achieve this model?
-Is it possible to vary the hole wizard to have csnks at those locations?
Here is the part in its folded state. The csnk holes are applied while it is in its flat state.
This is the resultant flat pattern. The csnk features are gone and are shown as a thru hole. The hole callout on the drawing is correct however.
If I remove the csnk that is coincident with the pattern feature I get the expected flat pattern.
If I add an unfold right after the fold I get this mess.
Thank You!
