I need to group some parts to set the pivot point but the "Create New Group" button is always greyed out when I select more than one part. Anyone know what might be going on?
You have to make sure they are on the same twirl order. So you can group 2 parts or group 2 parts but not group a part and a group together. See images below.
Or you might need to merge models first then group within that model
After grouping select pivot tool to position it to the exact spot needed.
