FDFrédérik Drouin12/12/2017
I created a macro that create a note at a position in a drawing and then save this drawing as a PDF in the same folder, but now i want to delete this note after the save as PDF and i don't know how to delete it without selected it. Does anyone know how to do that ? Here is my code :
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
            If (swModel Is Nothing) Then
        MsgBox "No active file found in SolidWorks." & Chr(13) & Chr(13) _
            & "Please load/activate a SolidWorks Drawing and TRY again!", vbExclamation
            End
            If (swModel.GetType <> swDocDRAWING) Then
        MsgBox "Current file is not a SolidWorks Drawing." & Chr(13) & Chr(13) _
            & "Please Open/Activate a SolidWorks Drawing and TRY again!", vbExclamation
            End
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Dim myNote As Object
Dim myAnnotation As Object
Dim myTextFormat As Object
Set myNote = Part.InsertNote("$PRP:""SW-Short Date(Short Date)""   TYPE YOUR TEXT HERE")
If Not myNote Is Nothing Then
   myNote.LockPosition = False
   myNote.Angle = 0
   boolstatus = myNote.SetBalloon(0, 0)
   Set myAnnotation = myNote.GetAnnotation()
   If Not myAnnotation Is Nothing Then
      longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
      boolstatus = myAnnotation.SetPosition(1.18224818891099E-02, 7.61066835915902E-03, 0)
      boolstatus = myAnnotation.SetTextFormat(0, True, myTextFormat)
Part.ClearSelection2 True
Part.WindowRedraw
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtention As String
Dim NewFilePath As String
FilePath = Part.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtention = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtention & "pdf"
Part.SaveAs2 NewFilePath, 0, True, False
