Macro: Auto export DXF from flatten view
Question asked by Kishore K. on Dec 11, 2017
Latest reply on Dec 11, 2017 by Deepak Gupta
Hi Team,
I have a macro which will converts sheet metal to DXF.
Macro Process:
Sheet metal to Flatten and export to DXF and retract to UnFlatten,
Here I'm facing a error in  DXF file, After exporting from sheet metal part to dxf there is no view or drawing inside the DXF file it looks like empty sheet.
Can someone help me to find out the issues ?
Dim Part As ModelDoc2
Dim swModel                 As SldWorks.ModelDoc2
Dim swPart                  As SldWorks.PartDoc
Dim sModelName              As String
Dim sPathName               As String
Dim varAlignment            As Variant
Dim dataAlignment(11)       As Double
Dim swSelMgr                As SldWorks.SelectionMgr
Dim swFace                  As SldWorks.Face2
Dim swFeat As SldWorks.Feature
Dim path As String
Dim folderpath As String
Dim boolstatus As Boolean
Private Sub CommandButton1_Click()
Set Part = swApp.ActiveDoc
'If part is not sheet metal quit
If Part.GetBendState = 0 Then Exit Sub
Dim Featnum As Long
Dim Feat As Feature
'Travers through the tree starting at the end.
For Featnum = 0 To Part.GetFeatureCount - 1 ' To 0 Step -1
    'Select each feature
    Set Feat = Part.FeatureByPositionReverse(Featnum)
    If Feat.GetTypeName2() = "FlatPattern" Then
        Feat.Select (False)
        Part.EditUnsuppress2
       Exit For
Next Featnum
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("Face1", "FACE", 0, 0, 0, False, 0, Nothing, 0)
'Get Path and file name of the flat pattern dxf
path = Part.GetPathName
path = Mid(path, 1, Len(path) - 7)
path = path & "-Flat.DXF"
'Create or update flat pattern DXF
boolstatus = Part.ExportFlatPatternView(path, 0)
        Feat.Select (False)
        Part.EditSuppress2
'Inform the user that the file has been created
MsgBox "Flat Pattern DXF Created"
Regards,
Kishore
